92 Accord Wagon EX
Power Door 'LOCKS' work just fine. hit the switch on the door panel, or push down on the **** manually, it will lock all the doors. Now.. when i press the UNLOCK on the switch on the panel, nothing happens. Passenger side does nothing either.
Ok, here's the tricky part. The failsafe system that Honda uses works just fine. If i leave the keys in the ignition. open the driver door and try to lock it. it will automatically unlock the door again (as to not lock keys in the car). So. I know the power UNLOCK has power. but the switches are not working. I have replaced both switches as well. Still nothing.
Any help?
Any help?
Could be your lock control module
https://honda-tech.com/forums/honda-accord-1990-2002-2/power-door-lock-problem-2684063/
Q; i have honda accord wagon automatic my problem is went is cold de car and star runing feel lke it work whit 3 cilinders but after drive 10 or 15 minutes its work perfect, i make the smog test and pass perfect but y still filing the vivration went star runing the vivration feels on the motor not on the tires . i check te computer an te S light give me te code 7 and 8 .
breds2k
Aug 14, 2013 04:44 AM
pauwo
Feb 24, 2012 07:33 PM
