started p505
Old May 16, 2013 | 06:03 AM
fangsnu's Avatar
Default started p505
I've tried everything. Replaced IAC cleaned tb check for vaccum leaks replaced map. Bleed system tried everything unplugging 02 sensors. My calc load on my scanner is 77.2. It idles high at 1000 then flutcuates between 750 and 1500. On accel it will boog down and if its stalling then climb back up and I can't go faster than 5 mph. There is like a sucking noise when I open the air cleaner that wasn't there before. HELP PLEASE
Old May 16, 2013 | 07:28 AM
silkypillows's Avatar
Default Re: started p505
leaving all sensors connected, ensure your throttle plate is in the idle position, and restrict airflow to the air bypass port(s) in the TB. if your idle improves your iacv (top) or fitv (bottom port, if equipped) is most likely causing an internal vacuum leak.
is your engine coolant temp sender in proper working order?
year, sub-model/engine code?
Old May 16, 2013 | 07:51 AM
fangsnu's Avatar
98 accord 2.3 VTEC manual
Old May 16, 2013 | 07:49 PM
fangsnu's Avatar
Got it I had map and to switched sneaky sneaky
omar pelayo
Dec 3, 2018 10:50 PM
Justinmnhall
22
Sep 6, 2013 03:40 PM
dfjr0926
Mar 10, 2011 05:16 PM
JDM Panda
Feb 13, 2010 03:40 PM
I Like Hondas
Jun 11, 2006 05:35 PM
