WANTED: 1/4 mile times for GSRs or LsVtecs in EF's
Old Oct 23, 2002 | 12:03 PM
jdmDXrex's Avatar
Default WANTED: 1/4 mile times for GSRs or LsVtecs in EF's
hey guys i want to get an idea of what people are running in their EF's with 1.8 Liters or above. basically gsr's, lsvtec's and i guess b20 vtecs too thanks.
Old Oct 23, 2002 | 12:32 PM
xtrafastcivic's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (jdm88crx)
make one and find out.... Or search... Or meet dicks like me..... 88 hf GSR 13.9
Old Oct 24, 2002 | 03:25 PM
jdmDXrex's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (XtraFastCRX)
anybody else have times?
Old Oct 24, 2002 | 04:25 PM
speeddave's Avatar
mmm, seen jdm gsr ef run low 13's even 12.9w/slicks... i think that a 2000lbs(w/driver) car that makes 200hp to the ground, and runs slicks should sneak into the 12's.
Old Oct 24, 2002 | 05:54 PM
redcxhatch's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (speeddave)
my friend went 12.9 NA w GSR boltons, slicks, chipped ecu.
Old Oct 24, 2002 | 07:28 PM
JDM88EF9's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (redcxhatch)
These times sound pretty good.
Old Oct 24, 2002 | 10:24 PM
jdmDXrex's Avatar
what else did he have?
i have ran 13.20@102.5 and 13.23@103 with the following setup:
first gen b16 stock head
stock 96' gsr block
stock head gasket
stock intake
obx 4-2-1 header
2.5" crush bent exhaust with dragunfire muffler
110oct race gas on 19 degrees timing
chipped pr3 with spoon program 4500 vtec and 8500 rev limit (still running lean; not sure why with a supposed 9.8 compression and first gen b16 cams)
and lightened doors and 20x6x14 m/t slicks on Hx wheels for a weight of 1980 w/driver
and i was wondering trying to get an idea of what i could run with a gsr head and probably CTR intake cam and sprockets.
Old Oct 24, 2002 | 11:18 PM
raene's Avatar
A very, very good driver... I know him, the times are very real
Old Oct 24, 2002 | 11:28 PM
jdmDXrex's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (raene)
are you talking about redcxhatch? if so i wasnt doubting him i just wanted to know his whole setup im just curious on what i should do next. trying to get in on everybody elses setups so i can get the best out of all of them for mine
Old Oct 25, 2002 | 08:25 AM
JDM88EF9's Avatar
When you are using the B18C1 Block with a B16 head, do you use the GS-R head gasket and what timing belt?
Old Oct 25, 2002 | 09:09 AM
jdmDXrex's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (JDM88EF9)
yeah you use just a b16a or b18c head gasket they are both the same thing and gsr timing belt. the only other way you could do it would be to use a Ls water pump and an Ls timing belt which is slightly smaller than the GSR. but then again there is really no reason to do that.
Old Oct 25, 2002 | 09:59 AM
skunked's Avatar
13.0 @ 101 NA DC2 GSR
Old Oct 25, 2002 | 10:01 AM
jdmDXrex's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (skunked)
what pistons and cams are you running? thats pretty good....
Old Oct 25, 2002 | 11:36 AM
TmeX05's Avatar
use a gsr timing belt and head gasket
Old Oct 25, 2002 | 12:08 PM
JDM88EF9's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (tmex05)
Thanks
Old Oct 26, 2002 | 12:14 AM
mannyman's Avatar
El Veterano de Sur Califas
13.7@98 mph At LACR usdm gsr of course
Old Oct 26, 2002 | 08:12 AM
89 CRX SI's Avatar
Default Re: WANTED: 1/4 mile times for GSRs or LsVtecs in EF's (mannyman)
i know a guy ls/vtec, header CAI exhaust, chipped, 14.4 in a Si hatch. needs some tunning
Old Oct 26, 2002 | 09:25 AM
jdmDXrex's Avatar
Street tires or slicks Manny?
Old Oct 26, 2002 | 01:12 PM
CHRIS 1.8's Avatar
I ran a 15.9 with H/I/E/FPR/cam gears/ported manifold/bored TB/pulley/stock ecu.
All I can say is its a horrible time, but it was also my first time at the track.
Old Oct 26, 2002 | 02:32 PM
mannyman's Avatar
mt slicks...20/6/14. and they were too small, they werent biting for ****.
Old Oct 26, 2002 | 02:41 PM
jdmDXrex's Avatar
have you ran your car since? what were your 60ft's and 1/8ths?
Old Oct 27, 2002 | 11:14 AM
QikChik's Avatar
b18c1 in 93 si
i/h/e, crower cams. cam gears at -3,+4 ,55shot dry
14.5 all day long.
dynoed 145,121 w/out n2o, somethings wrong.
Old Oct 27, 2002 | 10:10 PM
mannyman's Avatar
havnt gone since..and when i ran the 13.7 it was with a 1.8 60ft.
Old Oct 27, 2002 | 10:18 PM
jdmDXrex's Avatar
1.8... thats biting pretty good, what kind of 60ft's were you expecting?
Old Oct 27, 2002 | 11:19 PM
mannyman's Avatar
yeah...but that was the only 1.8 that i got. the rest where 2.0-2.4 And i could tell that the slicks werent grabbing...... they were spinning like street tires. b4 they would bite right of the line hard!!! so im guessing i need something bigger.
