Frankenstien motor
Old Oct 23, 2002 | 11:59 AM
97F22B2's Avatar
Default Frankenstien motor
Alright i need help here, im gonna bypass doin research cause im lazy but i may build a frankenstein motor. An H23 bottom end with a H22 Vtec head. I need to nkow if anyone has one done and what exactly the power will turn out to be. It should drop in just like the H22 swap in my Accord with just shaving the driver side motor mount. I need feedback.
Old Oct 23, 2002 | 12:15 PM
VTECVillain's Avatar
Default Re: Frankenstien motor (97F22B2)
You know what we will tell you:
Old Oct 24, 2002 | 01:52 AM
STEALTHMODECOUPE's Avatar
my friend had the same setup and something with the crank and timing got messed up so hes getting a new motor
Old Oct 24, 2002 | 07:58 AM
vtec69's Avatar
Default Re: Frankenstien motor (STEALTHMODECOUPE)
https://honda-tech.com/zerosearch
Old Oct 24, 2002 | 11:16 AM
kinesistech's Avatar
Valve clearance problems will plague you if your over rev it. Its better just to use an h22. They are better to begin with.
Old Oct 24, 2002 | 11:21 AM
Kamin's Avatar
Default Re: Frankenstien motor (kinesistech)
'Lazy' and 'build motor'
should NOT BE IN THE SAME SENTENCE.
search. it has all your answers.
Old Oct 24, 2002 | 03:35 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Frankenstien motor (KAMiN)
frankenstein is a bad idea unless you've got money to fall back on in case of some huge problem. just go straight H22...better all around and easier to deal with.
search, too, you lazy ***.
Old Oct 28, 2002 | 06:10 AM
97F22B2's Avatar
Default Re: Frankenstien motor (Archidictus)
Im sorry fellas but im going with the H23 motor instead due to lower compression and i used to have one in my old Prelude and se was a competitior
Old Oct 28, 2002 | 10:33 AM
ImportHatch's Avatar
Doesnt sound like your gonna get far if you are too lazy to look up info.
Yager-
mjutila
Jan 7, 2012 09:20 AM
92hondalude
Dec 21, 2009 12:32 PM
93JDM_H22
Dec 4, 2007 04:30 AM
accord-25
Feb 7, 2005 04:09 PM
FLoSSnJERKS
16
Feb 6, 2005 09:24 PM
