89 integra M/C on 91 Rex
Old Oct 23, 2002 | 11:55 AM
blackturtle916's Avatar
Default 89 integra M/C on 91 Rex
anyone done this swap? got pix or a link to an article ? i kno what needs to be done but it would be nice to have a template or something that i can use as a basis......
Old Oct 23, 2002 | 01:33 PM
spettinger's Avatar
Default Re: 89 integra M/C on 91 Rex (blackturtle916)
if the 91 crx is an si, i would leave it alone. if it is an HF, then i would put on the SI or 90-93 teg brakes all around, with the matching master cylinder. i have teg brakes all around from a 90, 10.5 fronts and 9 rear discs, with teg prop valve and steel braided lines. stops quite well, even with old brake pads and rotors. with some upgraded pads and rotors the car would lock the wheels up without much problem, is my guess.
Old Oct 23, 2002 | 01:42 PM
Default Re: 89 integra M/C on 91 Rex (wreckedhatch)
so you used the 90-93 m/c?....if so do you have pix of it or a walkthrough?.....i am using the integra front but i am going to use the CRX SI rear.......
Johnny-Red
Sep 22, 2007 03:29 PM
95_red_dc
Jun 17, 2006 06:51 PM
spun Vtec
Mar 24, 2003 08:20 AM
civbeater90
34
Aug 1, 2002 06:08 AM
Cav
24
Jun 27, 2002 11:46 AM
