lets get this straight 88-91 SI wiring harness
Old Oct 23, 2002 | 11:51 AM
chirp2hrd's Avatar
Default lets get this straight 88-91 SI wiring harness
allright an 88 SI wiring harness will only fit an 88 and an 89 will only fit an 89 si and the 90-91 will fit both 90-91 so that means if my friend has a 91 dx he either needs an 90-91 si for his zc swap and he cant use an 89 right??? it wont plug in to his engine bay cause i had the same problem with the resister bot and injectors ?
Old Oct 23, 2002 | 02:38 PM
civicwagonman's Avatar
Default Re: lets get this straight 88-91 SI wiring harness (chirp2hrd)
only difference I've seen has been where the resistor box plugs in, and you can pull the pins out of the plug and change the plugs. anyone else?
prelude182
Jan 20, 2012 05:23 PM
scooterbuilteh2
Aug 31, 2009 05:11 PM
str8drift
13
Nov 25, 2008 09:52 PM
shivern
Nov 6, 2004 10:17 AM
