1992 accord ex-r help! linkage
So I picked up the car listed above for 250$! Anyways it runs but it doesn't seem to go into neutral or fifth gear, I was told to adjust my linkage? Can anyone shed some light on this? How would I go about this. I'm use to civics and crx's which don't have cable linkage
Thanks!
Thanks!
just check the linkage...assuming it's all still attached correctly, then your tranny is probably toast, which is why you got the car at a discount...best thing to do is to get a used one from the junkyard
i've done this just recently and couldn't be happier...just choose wisely...try to find one that has no transmission fluid leaks at the bottom of the housing
Thanks!
Thanks!
There is literally no way at all to adjust the linkage. Once it's on, it's on. Light shed. Just like I said in your other thread.
When you say the car doesn't go into neutral or 5th, can you explain just exactly what it's doing.
its either the pressure plate. or the syncros/sleeves/hubs are worn. transmission is shot. that is if all the gears go in with car off. if this is true and 5th feels likes its jammed i would be safe to say its the transmission
I just started the car, when I let the clutch out in neutral it acted as if it were in 1st. Then when I put it in first it wouldn't move toward, same with reverse
rridc
Feb 25, 2011 03:51 PM
BB6racer
Oct 31, 2006 08:36 PM
honcrx91si
Aug 25, 2006 08:24 PM
chad174
Sep 1, 2003 12:12 AM
