Garrett Coolant Feed/Return Hose Fittings For BB Turbos
Old May 14, 2013 | 08:07 AM
ej6sir-t's Avatar
Default Garrett Coolant Feed/Return Hose Fittings For BB Turbos
Have two 1/4npt inline hose fittings great for feeding coolant from the lower hose to a Garrett BB turbo and accepting the return of the coolant to the upper hose. I use these for my BB turbo setups I build. They are easier than welding fittings into the radiator. They are more efficient than welding fittings into the radiator because at engine speed the water pump creates a slight pressure differential between the two hoses thus forcing water through the turbo. there is no pressure differential when you feed and return from the radiator- because they are both coming from the same place. The resistance is the radiator creating a pressure diff, its simple physics, flow will take the path of least resistance. both for $50.
Old May 14, 2013 | 01:37 PM
ej6sir-t's Avatar
Default Re: Garrett Coolant Feed/Return Hose Fittings For BB Turbos
Forgot the pic lol.
Old May 15, 2013 | 07:09 AM
ej6sir-t's Avatar
bump
Old May 19, 2013 | 08:52 AM
ej6sir-t's Avatar
ttt
Old May 24, 2013 | 06:06 PM
ej6sir-t's Avatar
bump, someones building a BB turbo'd honduh
Old May 29, 2013 | 09:48 AM
ej6sir-t's Avatar
picture so you can see it in use
Old May 30, 2013 | 12:40 PM
ej6sir-t's Avatar
bumpppp
Old Jun 4, 2013 | 06:32 PM
ej6sir-t's Avatar
buy these
Old Jun 5, 2013 | 02:48 PM
SIKNASTREXO's Avatar
the ones pictured is black correct? which is the same as yours for sale
I read this on garretts website.. http://www.turbobygarrett.com/turbob...t_White_Papers
second article
FYI
Old Jun 6, 2013 | 07:20 PM
ej6sir-t's Avatar
second article
FYI
What are you trying to tell me?
Old Apr 19, 2014 | 09:55 AM
ej6sir-t's Avatar
Bump still forsale!
Old May 21, 2016 | 12:47 PM
Logan Gervais's Avatar
Originally Posted by ej6sir-t
Forgot the pic lol.
Hey man where did you buy these from might have to pick up a couple
silicone-hose
Aug 6, 2007 04:01 PM
billy hoang
Jan 21, 2007 01:17 PM
wannakno
Acura TL, RL & ZDX
Sep 15, 2004 06:48 PM
flip1199
Sep 3, 2004 05:22 PM
RTW DC2R
Dec 16, 2003 09:20 PM
