What K24 is better?
Old May 13, 2013 | 01:03 PM
CarlitoSpoonEG6's Avatar
Default What K24 is better?
Want to know which is better K24A Odyssey / TSX / Accord Type S/CR-V/ is for a project with a 93 civic
Old May 13, 2013 | 01:12 PM
doood's Avatar
been there done that
Default Re: What K24 is better?
the best drop in and go option is the k24a2 out of the tsx. if you're building it get the cheapest one you can find.
Old May 13, 2013 | 01:29 PM
Thanks for the help bro
Old May 13, 2013 | 02:06 PM
nealnanoHX's Avatar
Yep the K24A2 is the only K24 that has Vtec on both cams ie the true Vtec we all want and love. All other K24 motors only have Vtec on the intake cam and it is more akin to Vtec-E, only operating 1 intake valve in lower RPMs. Not saying that the other K24 motors are not good performers though.
Old May 19, 2013 | 04:43 AM
H.Veras's Avatar
True, but keep in mind you can always do the vtec killer setup using OEM rockers and you are good to go. It all depends on what the purpose of the car is.
Old May 20, 2013 | 10:08 AM
okk thanks
Old May 21, 2013 | 10:21 AM
kyosoeg6's Avatar
personally i say just go with the tsx motor. if you get your car tuned right away u will be more than happy with the power of a stock k24a2. especially in a light *** eg hatch.
Old May 24, 2013 | 01:48 PM
EC93's Avatar
so all k series motors have vtec? and the k24a2 doesn't have a point where it kicks in its more or less always locked on
Old May 24, 2013 | 02:22 PM
doood's Avatar
they all have a version of vtec.
true vtec like we all know with 3 lobes per cam on intake and exhaust with a fixed crossover point:
- k20a
- k20a2
- k20z1
- k20z3
- k24a2
all the rest have a version of vtec-e where below a certain rpm only two valves per cylinder open fully on the intake side. it's meant for fuel economy.
Old May 31, 2013 | 01:38 PM
Katman's Avatar
^ well, that is, until the new K24Z3 came out (engine in 2009+ TSX and 2012+ Civic Si), thats neither VTEC-E/fuel economy based.
k24Z3 makes the 200hp mark and runs a single lobe'd exhaust cam, but retain the 3 lobe intake cam.
Seems honda figured out 3 lobes on exhaust side isn't needed anymore to produce 200hp, tho the k24z3 is a bit of a unique engine (head mainly).
In regards to the OP, were you asking which K24 is best for say a stock build? or a primo high power k24 rebuild?
If stock build, yeah like all have said, the TSX (04-08) K24A2 is the best choice with minor mods that can/should be made to it (type-s oil pump).
Old Jun 7, 2013 | 07:46 AM
G23accord11's Avatar
Icon2 Re: What K24 is better?
Is the type s oil pump a direct bolt up
Old Jun 7, 2013 | 07:15 PM
doood's Avatar
the mating surface needs to be ground down a little to fit the k24a2 and k24a4 girdle. it's a direct bolt on for k24a1. there's also an oil jet that needs to be plugged.
Old Jun 7, 2013 | 09:55 PM
m_shake's Avatar
iirc, the rrc(fd2 type r) oil pump is pre notched for a true bolt on affair, if that's what your looking for. Think you need rrc tensioner piece too
Old Jun 7, 2013 | 10:28 PM
doood's Avatar
the type s pump is cheap and readily available. no reason not to get it.
Old Jun 10, 2013 | 12:31 AM
Katman's Avatar
truth be told. and also the scoop on the JDM FD2-R pump hangs a bit lower than a type-S pump's scoop that's partly due to the slight differences in oil pan design in regards to the Z3 vs. A2 pans. (z3 and FD2-R pans are the same).
Old Jun 10, 2013 | 04:43 AM
George Knighton's Avatar
H-T Order of Merit
You're absolutely right, that's a great motor.
But for a build, it'll be more trouble tuning because people aren't fooling with it too much yet.
Easiest solution is still K24A2. :-)
Old Jul 9, 2013 | 01:06 PM
jaydan1020's Avatar
2012-2013 Civic Si has the K24Z7...just so you know.
Old Jul 9, 2013 | 04:00 PM
kingofbattle909's Avatar
the one stamped: H22a
Old Jul 9, 2013 | 06:16 PM
Katman's Avatar
thanks
Old Jul 21, 2013 | 04:41 PM
K1under's Avatar
K24a1 direct bolt-on... from there you go either route but i would say buy which ever k is cheaper because the money you save you can put into the engine and probably produce better numbers
Old Jul 26, 2013 | 01:46 PM
GDLRM3's Avatar
K24A2
Old Sep 1, 2013 | 09:38 PM
Tenassi's Avatar
How much is worth a complete K24A2 swap these days? Engine, trannny, ECU, harness, accessories, all the goods..?
Old Sep 4, 2013 | 02:04 PM
k-seriesdelsol's Avatar
06+ TSX K24A2
Old Sep 11, 2013 | 03:26 PM
k24a8's Avatar
will the k24a2 bolt up to the 2006 accord or will you have to switch ecu?
Old Mar 4, 2020 | 05:01 AM
michael sonza's Avatar
Bro i need help...I have k24a3 if i replaced my camshaft i can get that vtec engagement?
