Are these Corbeau seat brackets for a 2nd gen CRX?
A few years ago I bought a set of Corbeau seats for my 1st gen CRX. The seller had them installed in a 2nd gen CRX, so I had to buy different brackets. I still have the ones that came with the seat.
Can anyone verify that these are the correct brackets for a 2nd gen CRX? I want to sell these, but want to make sure they are correct before I post them.
Here are some pics. Can someone familiar with the seat rails on a 2G CRX validate that the mounting points appear to be correct? Both brackets have front mounts that are almost vertical, and in the rear there is one mount that is nearly vertical and another mounting point that is flat. Here are the pics:
Bracket 1 (Driver?)
Note the two nearly vertical mounting points on this side
Rear; note that the right side mount is more or less flat/ horizontal:
Front
Bottom
Bracket 2 (Passenger?)
Side
Rear; one side is vertical, the other side is relatively flat (just like the other bracket)
Front
Bottom
Oddly enough one of the brackets has a sticker on it that says "Mitsubishi Evo", however I think it is mistaken. I have looked at the Mitsubishi brackets and they look totally different.
Any help you guys can offer is much appreciated!
Bracket 1 (Driver?)
Front
Bottom
Side
Front
Bottom
On the 2g CRX the front ones should be angled like the one on the right side of your first picture, but both rears should be flat/horizontal.
Those shouldn't fit a 2g CRX.
Thanks Spug! Damn...not the answer I was hoping for. With no markings on these things, I'm out of ideas on how to figure out which cars these will fit. They may just end up in the trash.
Los.
Dec 24, 2005 08:19 PM
REX VT
Jul 9, 2002 11:55 PM
