Accord loss of power PLEASE HELP.
Hi Guys im trying to help my aunt with her 1994 accord. Her car seems to start losing power once the engine warms up. when the problem starts up you can press on the gas but there is no response from the car(no acceleration).
The car is manual, its not the clutch that was just replaces it feels like a lack of gas or spark. i checked vacume lines but did not find a leak, and the car idles fine so i know its not vacume related. Anyone have any suggestions on where i can begin trouble shooting or have had this happen in the past.
MY TO CHECK LIST
*spark plug cable/distributar rotor & contacts.
*gas pressure
*spark plugs
* If pressure doesnt check out the gas pump
*02 sensors
Any others i should add to my list? Thanks in advance. !!!
MY TO CHECK LIST
*gas pressure
*spark plugs
*02 sensors
im guess no. but suspects would be, weak spark, weak fuel delivery, low compression, limp mode, i would say maybe o2, intake air temp, tps might now be working right even tho it doesn't fit with the warm up loosing power, map sensor not reading right either, check engine light on? if your loosing power it has to be on if not.... does the check engine light come on when you let the fuel pump prime?
limp mode ? i have delt with that for k series but was not aware that accords would go into limp mode. imma scan it and pull some cells and update thanks for your imput noone botherd except for you lol
yes obd1 cars do go into limp mode as well. a 94 doesn't have obd2 port so you can't scan it. check the passenger kick panel should be a two wire plug most likely blue and jump it. might have a code stored that she might have missed and just never came back up
cuseikan
Nov 29, 2007 05:30 PM
