Need help!!!! Crossmember question! In desperate need! Help!
Old May 12, 2013 | 04:30 PM
93till's Avatar
Default Need help!!!! Crossmember question! In desperate need! Help!
Rear crossmember a bent. Went down to pick and pull and grabbed a rear crossmember. Took all day! Pulled the lca. Off tie rods. And the steering column bolt. But question is ... When I replace mine is there any way to avoid removing my rack and pinion or am I going to have to pull it all out and put it back in with the new crossmember???
Old May 12, 2013 | 06:31 PM
B_Swapped93's Avatar
Default Re: Need help!!!! Crossmember question! In desperate need! Help!
would help is you said if this is a G2 OR G3 teg and a few more specifics
Old May 12, 2013 | 06:43 PM
m4xwellmurd3r's Avatar
gen 2 and 3 are basically the same in this regard. rack and pinion is bolted to the crossmember if im not mistaken
Posted from Honda-tech.com App for Android
Old May 12, 2013 | 08:43 PM
93till's Avatar
Sorry it's a 93 so 2nd gen? And yes it is bolted to the crossmember but what I'm asking is when I pulled the one off at pick n pull I had to disassemble the power steering box on the rack and nock the pin out and the the rack and pinion slid right out. So the question I'm getting at is there another way ? A faster simpler method I'm over looking? Or do I have to unassemble and reassemble it all in order to just change that crossmember?
Old May 12, 2013 | 09:43 PM
you have to unassemble and reassemble it
Old May 13, 2013 | 07:02 AM
93till's Avatar
****. Alright not looking forward to it lol but thank you!
96romaEK
Feb 14, 2010 12:52 PM
Luckywhiteboi
Feb 28, 2009 10:24 PM
diswunfoo
Dec 2, 2008 06:46 PM
golfandcars
Nov 12, 2008 09:50 AM
