help me find my oil leak!
so last week i blew my seals to my turbo. i put my replacement on and my car still smoked. oil is coming from the hot side of the turbo and through my downpipe. im running a restrictor and as far as i know my drain line looks good. can somebody help me out. im so lost lol. thanks
Picture of oil return line ? More info ??? Those seals don't work how you think they do. Oil will either leak past them or it won't. They are metal rings. Not rubber o-rings that have cracked/failed...
one would say its the brand of the turbo you have selected, but do you have a pic of where the leak is happening? i kind of see some oil on the hot side of the turbo. your return needs some material improvement
Thats the chance you took when buying from fleabay, if an oil leak is your only failure conisder yourself half lucky.
Buy another and try again?
Or bite the bullet and buy a quality piece
Ever thought that it could be residual oil coating the downpipe from the original turbo. Once hot enough, is now burning off. Could happen. Seen it before.
it came with a 90 day warranty so ill just get a new one. and i dont have 600 for a turbo plus im only running stock internals. im going to upgrade when i do bottom end work
im a cheap **** cause i dont have 600 dollars to spend on a turbo? why spnd that money when im running stock internals its not needed. this is my first turbo setup so cut me some slack.....
I'm sorry but you'll learn the hard way then. You're better off leaving it alone then bombarding a good solid car with cheap crap. Just get your money back and save up. You don't have to have the car up and running within a month. Be patient, save...
