Tps readings question
Old May 11, 2013 | 07:22 PM
Kid-jdm-teggy's Avatar
Default Tps readings question
I got a reading of .55 at idle, and at WOT 4.60 for a 95 b18b1. Is this good because i know you need it at .5 and 4.5? Also, i notice when im cruising in 4th or 5th that i cant keep a steady speed. For example, i will cruising at 40 but if i try to hold it still there, it will act like the throttle isnt engaged, but if i give it throttle so it wouldnt slow down, it will go faster. I cant keep it steady, so could the readings of the tps be the culprit?
Old May 11, 2013 | 07:26 PM
B_Swapped93's Avatar
Default Re: Tps readings question
So are you saying it hesitates/stutters at 40 ? could be a dead spot in your tps did you check for them when you calibrated it ?
Old May 11, 2013 | 07:40 PM
Like, you know how when you're in gear and let off the gas and it makes that noise and slows down, it does that when i try to keep it steady cruising at any given mph, so i have to give it more gas then let off and that gets annoying. And i haven't adjust it yet because i got to buy a dremel tomorrow to cut off the screws. My question is could the tps readings be the cause?
Old May 11, 2013 | 07:41 PM
It cant keep steady in any gear btw, not just 4th and 5th
Old May 11, 2013 | 07:58 PM
the over readings not so much dead sport(s) yes they'll do that.
Old May 11, 2013 | 08:00 PM
How do i test for dead spots?
Old May 11, 2013 | 08:23 PM
Blackhalo6's Avatar
rotate the throttle slowly while watching voltage, if it jumps around or disappears at some spot during the time you open it, it had dead spots
Old May 11, 2013 | 08:29 PM
Oh, then no, my tps doesn't have a dead spot. It goes up smoothly to 4.6v. Any other ideas why it cant to cruising at a steady speed? Maybe something with the throttle cable?
Old May 11, 2013 | 08:30 PM
hmm well how new is your cap and rotor
Old May 11, 2013 | 08:40 PM
Blackhalo6's Avatar
check your iacv mine was fubar and gave me something like that
Old May 11, 2013 | 08:53 PM
I believe they stock, so 18 years maybe. Not sure
Now that you mentioned it, my car idles really high on start up (1600rpm), even after like 20mins of driving. Sometimes it does go down to a constant 800rpm. Could the iac cause this?
Old May 11, 2013 | 09:11 PM
Blackhalo6's Avatar
yep. take it out and clean the **** out of it, also 20 yr old ign system is gonna need replaced
Old May 12, 2013 | 08:13 AM
S2BumpsticksGSR's Avatar
Clean out the throttle body, too. There's most likely carbon build up behind/on throttle plate.
HGZ
May 4, 2013 11:32 AM
Costco
Nov 17, 2011 06:29 PM
hbyrd8701
Apr 5, 2009 07:57 AM
dra600n
Nov 4, 2007 11:47 AM
NikoZai
Mar 18, 2006 04:59 PM
