how much to torque turbo to manifold studs?
Old May 11, 2013 | 08:34 AM
90210tegrunner's Avatar
Default how much to torque turbo to manifold studs?
I got a new cast go autoworks log type manifold with a t3/t4 turbo. Go autoworks gave me steel studs to attach. Ive heard horror stories about this joint loosening from the heat cycles and vibration. I bought some stage 8 fasteners for this. What is the proper proceadure for installing studs in a exhaust manifold and how high do I torque the nuts down with this kind of setup. Do I just hand tighten the studs to the cast manifold and then torque the stage 8 nuts down? I just don't want to over tight n them because it could stretch the stud correct?
Old May 11, 2013 | 10:45 AM
Muckman's Avatar
Moderator in Chief
Default Re: how much to torque turbo to manifold studs?
Do you mean grade 8? Do you know what diameter they are?
I would torque a M10 size fastener to approx 40ft-lbs.
Old May 11, 2013 | 12:56 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
http://www.stage8.com/
Old May 11, 2013 | 03:41 PM
Muckman's Avatar
Moderator in Chief
Interesting.
hypeRhatch
Nov 10, 2013 03:01 AM
DC2Dave
Apr 9, 2007 11:18 AM
GIANT
Mar 5, 2003 01:52 PM
Teg4e
Jun 26, 2002 09:07 PM
