Euro CL9 K24 Dyno Inside
We dynoed my friends stock k24 accord before mods and after mods couple of day ago it picked up 30whp and it leaned so much that the AFR is almost 13.5 now. here is a pick of the Graphs overlayed. Mods were PLM CL9 Header and Skunk2 Megapower Exhaust.
and have wrong AFR.... as I said tuning must be done with proper ECU managment in first step. BTW I have CL9 Euro with better I/H and Hondata FlashPro ! With proper tune you gained much more !
13.2:1 is definitely not to lean, and many engines respond very well to 13.2-13.4 afr on pump fuel (when the CR is pretty low).
13.5 is a bit on the risky side since it might get even leaner in certain condidtions, but I doubt it is a problem on a stock engine with stock management.
Off course the result would be much better with a proper tune, but the results are still good given the little work that was done.
Quick question..your saying k20a2 in the cl9...im wanting to add a k20 type r top end, but struggling to find someone in the uk who is capable of remapping it, ive been told to get a tsx ecu the 07-08 ecu as this will accept the flash pro, any help would be appreciated!
b20bFourDoorCivicLX
Engine Management and Tuning
27
Dec 5, 2013 08:55 AM
Traction
Sep 12, 2004 09:55 PM
