Turbo Build 10.8:1 compression! undergo. Updated Pics
Old May 10, 2013 | 12:38 PM
Michael_accord's Avatar
Default Turbo Build 10.8:1 compression! undergo. Updated Pics
Alright fellas, i've been in the game since last april(2012) and never posted here no pictures of my ride or any of that sort just signed up. I have very big plans for the accord and plan on finishing big spending end of May. Got the car last april for my birthday, attained a job last November. I'm 19 don't flame cause i save for what i want.
Guys i chose the k20 9.8:1 pistons which would put me to 10.8:1 i have E85 around but i think i can get away with my power goal on 93 pump gas without a knock. 400+whp high boost, 350 mid, around 250 wastegate but im sure my 8psi wastegate will yield more than that.
The block is at the machine shop as of Friday May 10th 2013. Should get it back sometime next week and then i begin to put her back together.
I do have a turbonetics turbo which im thinking to rebuild and just use instead won't hurt.
Turbo set up:
ebay .57 trim turbo Purchased (will upgrade to precision as soon as i get back from vacation and dyno tune her. Will be street tuned before i leave)
Ebay cast mani Purchased
Uploaded with ImageShack.us
Mishimoto intercooler Purchased
550cc injectors Purchased
p28 Neptune rtp Purchased
Oil sandwich plate Purchased
Walbro 255 Purchased
tial wastegate 38mm gonna strip the paint and make it straight silver Purchased
Oil feed/return Purchased
cx racing intercooler piping 2.5" Purchased
Aem wideband guage Purchased
F23a Race engineering rods Purchased
2 wire iacv and adapter plate Purchased
K20 9.8:1 wiseco pistons Purchased Update April 25th 2013
acl race rod bearings std Purchased Update May 2nd 2013
OEM timing belt kit/full gasket set/Head gasket Purchased Update May 2nd 2013
Main bearings??? Acl hx Purchased Update May 3rd 2013
Blitz Bov Had
H23 headstuds Not purchased to be on the 9th of May
Act clutch kit Not purchased to be on the 16th of May
That is all to the turbo build and bottom end being put together.
f23 head
Bisi springs/retainers will be purchased down the line and the cam gear.
Heres the ride: Feel free to shoot out your opinion H23a head or F23a Head?
Old May 10, 2013 | 12:44 PM
Default Re: Turbo Build 10.8:1 compression! undergo. Updated Pics
May 9th 2013 before block was dropped off.
Old May 11, 2013 | 02:19 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Just what kind of game are you playing?
Word of advice, keep that garbage can empty - you ARE going to NEED it.
You could start filling it with those Smart Fire Injectors. If you have to ask why, then you didn't do your research.
Old May 11, 2013 | 04:11 PM
TheShodan's Avatar
Moderator
Car looks clean, except for that "illest" nonsense. My younger brother has the same car in an Auto.. *snicker*
Old May 11, 2013 | 04:14 PM
Spawne32's Avatar
Old May 12, 2013 | 10:51 AM
Okay *******, not here to please you, don't like what you see. Kiss my *** and go about your own business.
Old Jun 2, 2013 | 06:18 PM
Kevs02Accord's Avatar
Which manifold and downpipe did you use?
Old Jun 2, 2013 | 08:15 PM
damnilovepuzz3d's Avatar
He's trying to help you.. those are notoriously bad injectors.
Old Jun 3, 2013 | 01:05 AM
yungkhmer's Avatar
**** it let him fail if hes gonna respond like that lol
Old Jun 10, 2013 | 07:16 AM
For those who cared. Take a look. http://www.6thgenaccord.com/forums/s...ad.php?t=46104
And to those who think i would "fail" whatever. Planed on getting id injectors after my vacation anyway.....You know nothing about me so i assume you think i'm stupid. But okay.
Old Jun 10, 2013 | 09:29 AM
TheShodan's Avatar
Moderator
Ok. Real talk here.. Based upon this..
Questions: Answer these more for yourself, not for me....
A. Wastegate opening is pointing upward.. Do you plan to do some sort of weird hood exit, or flip the gate around to point downward properly past the engine bay to either merge into the exhaust system, or vent to atmosphere
B. Radiator upgrade.. Is there a plan there, or to actually get a radiator that will be able to cool down those increased cylinder pressures. I'm just saying that every accord from that year that's done this, always wound up changing radiators.. You'll really need a replacement if the dumptube is not properly made.
C.eBay turbo question .. you posed a question as to whether or not an impeller blade would cause damage to the rest of the car. Actually the answer is no, not immediately, but the foreign debris that a broken blade creates destroys the turbocharger, goes into the oil system and could destroy your bearings. And yes, that's not a rare occurrence when using those kinds of parts. In addition, a 6262 would leave you in the cold compared to smaller, turbochargers that would take better advantage of the rpm band and cylinder head design that you have on that car. Not saying you can't use a precision, but going with this "bigger is always better" approach, can easily leave you in Grandma's 1992 Grand Prix dust because you oversized the turbo thinking more of your ego than the application.
Soo.. good luck.. no flaming, all business, but.. stuff you need to consider, as it seems as though it hasn't been addressed in either of your two threads.
Old Jun 10, 2013 | 09:52 AM
You know i really appreciate your comment, to answer you. Yes a radiator will be also purchased. I am not using the 6262 i'm running a turbonetics 60-1 trim right now at this very instant and will continue to use it. There is nothing within my build that will jeopardize my car. It is done right. Wastegate...good thinking there is already a tube i have made for it that leads down the bay and is open in the direction of the exhaust. Anymore concerns?
Old Jun 10, 2013 | 10:19 AM
TheShodan's Avatar
Moderator
Nope. Gotta give bravery points for running the Mark II Deltagates. I hadn't run one of those in.... well, let's just say a very long time.
Old Jun 10, 2013 | 08:33 PM
Lol on the wastegate, yeah its an old one and a strong one at that, i still have tial here but since this was already on the manifold i didn't feel the need to just take it of to put my other one on.
Old Jun 10, 2013 | 10:31 PM
TheShodan's Avatar
Moderator
mmkay.. I'll just say this. There's a reason WHY those deltagates aren't used anymore. mainly... They don't hold boost pressure very well outside of the 9psi range without stability issues.
Old Jun 11, 2013 | 06:23 AM
citrus3000psi's Avatar
But its a "strong" one....
Old Jun 11, 2013 | 01:02 PM
Well thats nice to know, have you had issues with it? Because its been 4 years so far running with this on another car...i will take my chances....if anything hello tial.
Old Jun 11, 2013 | 01:20 PM
TheShodan's Avatar
Moderator
Again. steady boost issues are common, depending upon how high over 9psi you get. Hopefully the motor won't grenade before you get the TiAL from the inherent spikes from that thing. Man, in 1998 when they were all the rage, 2 out of 5 lost their engines due to the adjustment screw on that gate.. So.. hopefully you'll have better luck
Old Jun 11, 2013 | 06:56 PM
wantboost's Avatar
Who is Mr Robot?
That's why everyone upgrades to their larger 42mm gate
But honestly TiAL pretty much is the industry standard. Turbosmart also makes an affordable 38mm gate with quality on par with that of TiAL
And it's nice to see people going high compression on turbo builds. A few years ago we would've all been told we were crazy and that it wouldn't work
Look at us now lol
Old Jun 12, 2013 | 10:28 AM
Its more of a clearance issue here, when i do upgrade radiator and i will go around shopping for a nice new wastegate. Alot of people here bash on everything...the car is not complete to the way i want it. I don't need advice from anyone here i was just sharing my accomplishments. I know what needs to go and what doesn't. and @ wantboost damn right high comp ftw!! :D
Old Jun 12, 2013 | 06:37 PM
bigG's Avatar
a few years my d16 was stroked out and 10.5:1 comp with a gt28rs and boy oh boy was that a fun car that pissed off alot of people. anyway with that setup and your goal i would go bigger on the intercooler. with the high compression you want everything as efficient as possible or you will be rebuilding again before you get your set up "the way you want it". but you will either take the advice or learn on your own 2, to each their own.
Old Jun 13, 2013 | 04:04 AM
True, i'm not too sure if you guys understand me very well. This will be a 400+whp vehicle...not daily driven at 400whp all day everyday. 250whp daily is my goal. As you can see the car isn't a race car.
Old Jun 14, 2013 | 09:27 AM
Now for those with my "exhaust issues" here, smile, happy?
Old Jun 14, 2013 | 12:08 PM
TheShodan's Avatar
Moderator
Its not us that need satisfying, so please knock it off, and stop getting so defensive. I'm sure we can appreciate different types of turbo setups, but if this is the persona you want to portray yourself as, I mean... we can all hit the "back" button and move on, ya know? Relax, people are trying to help.. some less politely than others.
Technically, the dump routing works, but would have functioned even more efficiently, if the gate outlet flange were rotated to its flange 180 degrees, pointing downward. The top of the gate would have been facing the same direction, and you would have saved even more exigent heat and used less piping to get it done. As long as you're happy with it, and won't melt your radiator, that's all that matters in the end, correct?
Old Jun 14, 2013 | 12:44 PM
You're right that is all that matters i come of the way i do in regards to how people come off at me. Telling me to throw things in the trash is utterly disrespectful to me from the start. It works 2 ways. I'm a nice guy and can take the constructive criticism in the same way you all would want to take it. The build will have updates along the way never did i say it was done. It will have 1000cc inj, go autoworks half size rad, aem fuel pressure regulator before i even take it to tune. With that said people should just wait and stop with the nonsense comments like "550cc" won't cut it.....of-course it won't what am i retarded? 90% of the people in the u.s would never break down and rebuild their engine.
