Interior Bulb Size Guide
Old May 10, 2013 | 04:18 AM
hondalion's Avatar
Default Interior Bulb Size Guide
I've replaced my interior lights with LED's. The place I ordered from sells them as a kit and has limited color options. I want to order from somewhere else but I don't know the right sizes.
Anyone have a good bulb size guide for a 6th gen? I'd like to order my bulbs individually if possible as well in case I need to replace.
Thanks
Old May 10, 2013 | 04:47 AM
hondalion's Avatar
Default Re: Interior Bulb Size Guide
Here's one place that shows sizes, but unfortunately not what I'm looking for. Right now I'm looking specifically for climate control.
http://www.myhidkit.com/pages/Application-Guide.html
Old May 10, 2013 | 05:07 AM
TheMuffinMan's Avatar
He knows where you live!
http://www.hondaautomotiveparts.com/...L+%28+01-02%29
That might give you a bit better reference point. Those are the OEM part numbers and their description/voltage/current.
Old May 11, 2013 | 05:52 AM
hondalion's Avatar
Checking it out, thanks.
Old May 11, 2013 | 07:44 PM
TOM2RN's Avatar
You might also try superbrightleds.com. They even have a vehicle bulb finder on the home page just below their logo.
Old May 11, 2013 | 07:58 PM
silkypillows's Avatar
http://www.modifiedlife.com/honda-ca...b-size-guides/
(links on right)
depending on which bulb you are changing in the CC, the main lights usually match the cluster lights/acc lights. but I would say take them out and check for sure, if you can't* find substantial info.
if you are changing the actual button bulb (a/c - different vent positions) they will most likely need to be custom, as in mounting bulbs in the stock housings.
Old May 13, 2013 | 08:37 AM
hondalion's Avatar
I was able to figure it out eventually, looking at the stock OEM site helped me get to the right voltage and stuff and from there I was able to identify LED's that would fit.
I ordered from superbright, should find out soon if I got it right.
I'm replacing a couple LED's that don't seem to make contact well and flicker. Nothing I do seems to work. Being a novice at the time I think I damaged the LED's putting them in so I'm hoping that starting with a brand new one will make the difference.
Old Jan 21, 2014 | 04:36 PM
professorman's Avatar
I need to replace a few of my burned out bulbs for my gauges/buttons on my 94 Accord. Is there any advantage to going to LED or sticking with conventional bulbs?
das_thunder
Jul 4, 2011 12:45 PM
azjared
Oct 19, 2008 02:34 PM
carlossanta
Honda Civic (2001 - 2005)
May 17, 2007 10:25 AM
GraphiteMW
Apr 4, 2007 07:04 PM
ITLNstallion818
Dec 22, 2005 07:24 AM
