AEM Series 2 base map
Hey I have a AEM Series 2 30-6030 ECU for a K-Series. I'm looking for a way to create a base start up map for my setup. So far I cant find any information on how to make such a map. Any help with this is appreciated.
I'm aware of that basic street car map. My concern is that map is not made for a motor that is running 14.5:1 compression, no vtec, no Vtc, ITB's and E98 / methanol. Have to much money in motor to install a map made for a street car.
That is why you need to make the adjustments to the map prior to starting the car to suit the map to your needs!! No one is gonna have a base map just for your set up!! If your asking this prob best to contact someone to tune the car!!
Here is a basemap for you. Start with the one that is provided. Turn off the VVC. Turn off VTEC. Take some of the timing out. Are you running E98 or Methanol both require a different amount of fuel for a tune. Change the injectors in the wizard because they are most likely not stock. Probably want to switch the fuel map from MAP to TPS related since it is running ITBs. Look at the wideband and tune from there.
Or the more simple approach if you don't know how to tune the AEM or how to set it up take it to a tuner.
