1992 Civic no power to fuel pump new to Hondas Help
Old May 9, 2013 | 09:02 PM
Hightower350's Avatar
Icon2 1992 Civic no power to fuel pump new to Hondas Help
I have a 1992 hatchback civic that has a D16y7 swap. It is my first Honda and it has never given me problems till now. It died on me while driving. So I have checked google and it has led me to Honda Tech everytime. I have read the similar problems that I am facing which is no power to the fuel pump. I have spark but no power what so ever to the pump. I have checked the wires back to the main relay. I have tried to jump pin1 to pin7 or pin5 five to pin7 I can feel the main relay clicking. I have not checked the ecu because I do not know how. I have checked the 31 fuse under the hood and also the number 24 fuse under the dash and they are good. I am getting no power with a multi meter when grounding and connecting to the fuel pump wire for the main relay. I have tried my best researching any help will be appreciated.
Old May 9, 2013 | 09:09 PM
Former User's Avatar
Default Re: 1992 Civic no power to fuel pump new to Hondas Help
Resolder the main relay.
http://techauto.awardspace.com/mainrelay.html
Old May 9, 2013 | 09:13 PM
ej7attack's Avatar
what ron said. id like to add there are videos for this problem.
Old May 9, 2013 | 09:19 PM
So even resolder if I can feel it click on and off I know I sound like a idiot.
Old May 9, 2013 | 09:22 PM
The main relay should click more than once.
When you turn the key from off to ONII), does the CEL remain on steady or turn off after 2 seconds?
Old May 9, 2013 | 09:23 PM
It clicks one time when switch is cut on and one time when turned to off.
sorry whats CEL????
Old May 9, 2013 | 09:24 PM
check engine light
Old May 9, 2013 | 09:25 PM
Its always on.
d_boi_swag's Avatar
Check engine light
Old May 9, 2013 | 09:27 PM
Click the Codes link in my signature. Are any codes recovered after jumping the service connector?
d_boi_swag's Avatar
one thing make sure you check the ground on the thermostat housing make sure its clean and tight
Old May 9, 2013 | 09:28 PM
Ok and that's the Gsomething wire ground everyone says and that is under the dizzy right
Old May 9, 2013 | 10:55 PM
HondaPartsHero's Avatar
Technical Hero
Old May 10, 2013 | 11:31 AM
I checked and cleaned the ground wires and tryed to pull the codes but it wouldn't blink so I tryed the pins being jumped on it didn't do anything.
Old May 10, 2013 | 11:33 AM
Originally Posted by RonJ@HT
Old May 10, 2013 | 11:50 AM
POPLERO's Avatar
this happen to a buddys car, and it was the main relay.. we opened it and what do u know, the soldering was cracked. luckily he had an extra laying around
Old May 10, 2013 | 03:53 PM
Bad fuel ground thanks y'all
BTaylor
May 29, 2022 03:35 AM
jun10r27
Honda Civic (2001 - 2005)
Dec 15, 2009 08:35 PM
gsrt nick
Oct 23, 2006 06:43 PM
95turboeg
Jul 7, 2006 11:38 AM
shyxboy
Jun 1, 2005 08:09 AM
