engine spinning in opposite rotation
Old May 9, 2013 | 08:25 PM
89ED's Avatar
Default engine spinning in opposite rotation
not my engine a b engine that i saw on youtube. a couple questions came up. how much would that cost to do. could it still rev to nine grand would vtec work still
Old May 9, 2013 | 09:53 PM
jdm_rb20's Avatar
Default Re: engine spinning in opposite rotation
I'm no master mechanic, and I know better than to say anything is impossible, but that just sounds fake. For it to spin backwards (and run), i would believe that the complete engine block would have to be fabricated to swap the intake/exhaust sides of the engine. Not to mention all the other finicky things that might be designed to be "directional"..such as oil pump, water pump (directional fins), thermostat, ac & power steering lines swapped.
Old May 9, 2013 | 10:14 PM
98ekb18c's Avatar
I've never heard of it on a b series. I've heard about people doing it to either h or f series (don't remember which or why). This was sucessfully done with the old school Buick "nailhead" engines tho.
http://www.v8buick.com/showthread.ph...-flow-nailhead
Old May 9, 2013 | 10:19 PM
98ekb18c's Avatar
http://www.cb7tuner.com/vbb/showthread.php?t=167371
Never mind. Reverse head on h22. Still rotates the same direction. If you got an engine to spin backwards, you'd have 5 reverse gears and 1 drive cuz now you're spinning the tranny backwards too
Old May 11, 2013 | 08:53 AM
Nickeg9Ej1's Avatar
look into this along time ago for rwd project, you'll need custom cams, starter, ignition, electric water pump and dry sump oil pump. not really worth it cause you can pick up a k24 for 600-800 bucks that spins that way already.
Old May 12, 2013 | 01:36 PM
jdm_rb20's Avatar
Is there some practical advantage or point to having an engine spin backwards?
Old May 13, 2013 | 02:36 AM
~sp33~'s Avatar
EFB055
They did it in the CD accord touring car, one of the reasons was for more optimal exhaust flow.
zeek1221
Jun 17, 2017 06:22 AM
rayray24
Apr 2, 2013 09:12 PM
thegatekeeper14
Mar 31, 2010 11:19 AM
Root79
Apr 8, 2007 07:23 AM
Hood386
Feb 9, 2006 08:06 AM
