D-Series Parts Galore...and more!!
This was a bunch of parts that my team and I had aquired to build a d-series monster, but since I had this LS/Vtec just laying around, I figured why not drop it in the CRX and tune it for real power. So we abandoned the D, and now the D-Series Parts are all up for grabs!! Make and offer on anything you see here through PM and I'll get back to you right away, Thanks!!
Here goes the list as best I can remember:
d16a6
Block (cleaned from the machine shop)
Crank
Piston Rods (attached to blown p29 pistons-ring landings)
Oil pan
Oil Pump
Intake Manifold
Misc lower end parts - ask
d16z6
Block
Crank - threw rod with this crank
Head
Oil Pump
d15b2
Running engine, about to be pulled complete
Has d16a6 head, runs strong
I have a e-vtec 1.6 head (looks like crap bottom side, but clean under the valve cover) but I dont know what year, someone can have it.....
There is a few other parts like
Caliper and rotor/hub assembly for 91 CRX si Left only
94 Civic 3 point front strut tower bar
94 civic c-pillar bar
88-91 CRX Rear Strut Tower Bar
Stock d16a6 Fuel injectors
d16y8 Intake Manifold with injectors and fuel rail
17 inch Kyowa Racing Rims with racing Slicks on them
Ask about any Item, a Price can be negotiated. I am also looking for a few key Items too for my LS/Vtec build(95 GSR head, 91 LS Block in 91 CRX Si) so maybe some trade if you have what I want. The photos are actual parts, and I can email more photos upon request
Header for LS/Vtec
OBD0 - OBD1 ECU Wire Harness Adapter
OBD0 - OBD1 Distributor Wire Adapter
5spd LSD b16 Cable Trans
Good Intake Manifold for LS/Vtec
d16a6
Crank
Oil pan
Oil Pump
Intake Manifold
d16z6
Block
Head
Oil Pump
d15b2
Header for LS/Vtec
