99 crv problem
I have a 99 crv 5 speed and whenever you go to turn around with the wheel all the way, there is a loud creaking noise coming from the rear of the car. a shop told me it could be the rear struts causing it. anyone know anything more on this
is it a creak or a grind? and does it come from the middle, back right or back left?
I know this is beating a dead horse around here but if you change that rear diff fluid only use Honda Brand Dual Pump Fluid
It's about $20 a bottle but it's the only fluid you can run, your rear diff has a clutch pack in there and running any kind of oil will jack it up.
crvan07
12
Nov 30, 2007 06:36 AM
