1996 Honda Accord LX- Exhaust pipe for CA emissions
1996 Accord LX 2.2l 4 cyl (non-vtec). Automatic transmission, CA emissions.
Need to replace the B pipe on my 1996 accord. According to mechanic, part number is 18220-sv1-315. According to Autozone, the correct aftermarket is Walker 55141.
I had a pipe I purchased from autozone, but I bought it before I knew my car was CA emissions, so it didn't fit (just my luck). And to make matters worse, he already removed the bad pipe, so now there's nothing b/w the cat and muffler, and the car is RIDICULOUSLY loud now.
Can anybody confirm that 55141 is the right part? Walker's website isn't much help.
Originally Posted by Honda
18220-SV1-315 018 001 PIPE B, EX. 296.27
That's not the number I come up with... I'm thinking something is goofy, as that above mentioned exhaust does not look correct...
I looked up the below diagram under '1996 Honda Accord 2dr LX'
18220-SV1-C30 014 001 PIPE B, EX. 317.63
So I looked up 1996 2dr EX and got this...
18220-SV1-C70 014 001 PIPE B, EX. 355.33
18220-SV1-C70 015 001 PIPE B, EX. 355.33
Albeit if your mechanic looks up a mid pipe for a DX it will be the correct part number.
Originally Posted by Walker Exhaust
And here is the 2.2 EX
46865 is 2.2 DX, LX models
55141 is 2.2 LX S.E. models
46924 is 2.2 EX
And that the proper Walker part number you need is 46865 or in Honda speak 18220-SV1-C30.
We'll discuss later where you can send the payment of brew and bitches to.
SKEET SKEET SKEET!!!
MAD MIKE, I have the same car 1996 Accord LX non V-Tec 4dr California Car. I bought some exhaust flange gaskets at O'Reilly and they are the wrong size. The ones I got are too big in diameter but that is all O'Reilly offers for my car. The diagram SV43-B0201F looks correct to my car judging strictly by the single muffler tail pipe. Most others have dual pipes on the diagrams. Do you have part numbers for those by chance? Or is it even the correct exhaust system?
Thanks
Thanks
The exhaust system and wheel base are no different between 2dr and 4dr, but Majestics site automatically assumes you have a S.E. when selecting 96 4dr LX.
What gaskets did you order and what were the part numbers? Did they not fit?
AFAIK the pipe diameters may be different with the resonator pipe but DX, LX, and EX all use the same gaskets. Don't know about the S.E.
For one they gave me a crush ring, which I believe this car doesn't even have. Autozone has the same parts just different manufacturers. I think I will go with the Walker gaskets. I had already chipped away all of the old gasket so I needed to put something in its place. I used the crush ring and got it to seal somewhat from B to C pipe.
The exhaust flange and cat gaskets are crush type. You just need to press it in enough to get it to hold, then torque down each of the three bolts just slight tad bit at a time so they don't leak or they will leak if you go too much on one side.
mad mike is correct. at least for my 97 accord lx 2.2 cal emissions mid pipe-46865
fit like a glove
also used
honda cat to midpipe crushable exhaust gasket 18393-SH3-S00
used the walker bolts for the rear connection but used the honda springs, walker gasket with plenty of anti-seize
and I bought some high temp spray paint from the hardware store to cover the welds because they rusted out first on my last pipe.
so I sprayed the contact surface with rubbing alcohol, then used the whole can painting the entire exhaust because I'm an overacheiver
thanks mad mike
fit like a glove
also used
thanks mad mike
