Rough idle after Timing Belt Change
Old May 8, 2013 | 08:27 AM
Meraut's Avatar
Default Rough idle after Timing Belt Change
So a mechanic i know did a timing belt job for me(Water pump and all that with a whole kit.) I picked up the car drove it home, noticed in the morning when i turned it on and let it warm up that at idle i could definitely tell it was louder, and the car itself was shaky. If i put my hands on the steering wheel i can feel the vibration a lot. Now hes going to open it up and make sure everythings all lined up and all that with a timing gun this weekend. Is there anything i can check in the mean time that may cause these symptoms?
PS. It wasnt that way before the job. Thanks for your help HT.
Old May 8, 2013 | 09:43 AM
djkurious's Avatar
Default Re: Rough idle after Timing Belt Change
If it wasn't like that before then he didn't set the timing marks/balance shaft/crankshaft correctly. Refer him to here: https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
Schoust
Apr 21, 2013 04:48 AM
violarules
Mar 18, 2008 10:53 AM
llevity
Jul 12, 2005 02:39 PM
spyderracing
Aug 27, 2004 08:39 AM
