rpm jumping
Old May 8, 2013 | 06:43 AM
hawker98's Avatar
Default rpm jumping
Hi I have a 95 integra ls with gsr motor and trans. When im cruising or idling or well doing pretty much anything my rpm gauge will tweak out jumping past redline the jumping to 0 rpms or any were inbetween the engine will either lose all power and die or start missing and back firing. Anyone have any ideas what may cause thos even the old ls motor did this I dont think the swap did it. Thnx for your help
Old May 8, 2013 | 07:32 AM
SolScifen's Avatar
Default Re: rpm jumping
I'm pretty sure that means your icm/ignitor in the distributor is no good.
Old May 8, 2013 | 04:45 PM
hawker98's Avatar
Ok replaced icm everything is fine on short runs but still does it in vtec
Old May 8, 2013 | 05:18 PM
fcm's Avatar
fcm
Old Fart
Check the connections to the ICM and coil, make sure they are all tight, you may have to "crimp" the "quick release" terminals a lettle to tighten them up. 94
Old May 13, 2013 | 10:01 PM
hawker98's Avatar
Found problem it was lose ground on thermostat housing thnx srry for late update
Naazel Sirez
Sep 27, 2018 03:17 AM
Built4Battle
Aug 10, 2010 05:01 PM
dansred2000si
Feb 19, 2008 05:24 AM
B18c1EKCpe
Mar 11, 2003 09:38 PM
