Siemens Deka 880cc
Old May 7, 2013 | 09:27 PM
TheToaster's Avatar
Default Siemens Deka 880cc
Siemens Deka
Model Number 3105
CC/Min: 872
Lb/Hr: 83
Connector: Bosch EV1
Spray Pattern: Pencil
Ohms: 2.35
Recommended Pressure Min. 36 PSI (2.5 bar)
Recommended Pressure Max. 87 PSI (6 bar)
Voltage: 8-15 Volts, Nominal 13.5 Volts
Amperage: Peak 4.0 Amps/ Hold 1.5 Amps
Injector Dead Times:
10V: 1.46
11V: 1.20
12V: 1.00
13V: 0.85
14V: 0.73
15V: 0.62
Flow tested 5000 (Actual) miles ago and reported 100% performance from Xenocron with consistent output.
Fits: B, D, H, F, as well as other vehicles with the same dimensions.
OBD0 and OBD1 Clips will fit.
(Pretty Standard)
Good for 10s in the 1/4.
~450WHP+ Capable
Test sheet will be included in packaging.
PM Me Offers
$250 Shipped
Old May 8, 2013 | 08:33 PM
TheToaster's Avatar
Default Re: Siemens Deka 880cc
Bump
Old May 9, 2013 | 08:23 PM
TheToaster's Avatar
bump
Old May 11, 2013 | 09:20 PM
TheToaster's Avatar
bump
Old May 12, 2013 | 03:46 PM
TheToaster's Avatar
bump
Old May 13, 2013 | 02:36 PM
TheToaster's Avatar
bump
Old May 14, 2013 | 02:20 PM
TheToaster's Avatar
bump
Old May 15, 2013 | 02:50 PM
TheToaster's Avatar
And bump.. Don't let the numbers scare you guys, just trying to help you out!!!
Old May 18, 2013 | 11:54 AM
TheToaster's Avatar
bump
Old May 19, 2013 | 11:48 AM
TheToaster's Avatar
bump
DONTSLEEP_
Northeast (Sales)
26
Mar 8, 2012 07:40 AM
dizzyroc88
Aug 18, 2010 03:19 PM
dragrace162
Northeast (Sales)
225
Jun 3, 2010 07:26 PM
da9leo
Jun 18, 2009 10:53 PM
Bseriescivic5
Sep 19, 2006 10:01 AM
