Speedo needle crapped out HELP!
So last night I was doing a 2nd gear pull. Popped off the rev limiter for all of a split second and watched my speedo needle fall flat. The rpm needle still works fine. Suggestions?
Yeah either the plug popped off the VSS, or the VSS died. There could also be a wiring issue elsewhere, but those are more likely, especially if you guys were working back there.
Didn't you put a new one on recently?
