Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Swaybar size for 2011 Pilot
Old May 7, 2013 | 06:25 AM
johnjk's Avatar
Default Swaybar size for 2011 Pilot
Greetings,
Two questions for you.
1. Does anyone know the diameters front and rear for the sway bars on a 2011 Pilot EX-L?
AND....
2. Does anyone know where I might find Poly replacement sway bar bushings for the 2009-2011 Pilot?
I see a lot of universal fit for the Pilot, but nothing on direct replacement. My factory bushings are worn and I'm starting to get some clunking from the front end. I have 67K on my Pilot.
Thanks
Old Jun 20, 2013 | 09:17 AM
MrDX's Avatar
Default Re: Swaybar size for 2011 Pilot
The swap you're looking for is using the rear sway bar from the MDX. You'll need to get the swaybar from the MDX Advanced Package and bushings as the end links and bushing brackets are the same. You'll be going from a 25mm to 27mm.
Mikes2000civicsi
Suspension & Brakes
Mar 27, 2008 10:17 PM
743power
Sep 16, 2006 01:53 PM
EFSiR
Apr 6, 2006 05:54 PM
GreenBean
Feb 26, 2004 01:01 PM
Regular Series
Nov 24, 2002 05:12 PM
