camber kit issues
Old May 6, 2013 | 10:57 AM
lazy14's Avatar
Icon2 camber kit issues
so i had a bad upper ball joint n got a front camber kit, i cut the lip in the wheel well for it but with the ball joint all the way in or out when its on the ground there is no give at all in the suspension, does it need aligned? its a 89 ef sedan
Old May 6, 2013 | 12:13 PM
Tyson's Avatar
Default Re: camber kit issues
You suck at describing your problem coherently.
I have no idea what you just asked.
And I'm guessing you need an alignment regardless.
Old May 6, 2013 | 12:21 PM
4drEF's Avatar
Keyboard Humorist
No give at all in the suspension?
How low are you?
Sounds like you dropped so low that the upper A-arms are hitting at the top.
Old May 6, 2013 | 12:43 PM
lazy14's Avatar
its got 2.5 inch drop springs, n i can see bout an inch between the ball joint and the top of the wheel well, but the front end has no give, i would probably be better off getin the oem ball joints done
Old May 6, 2013 | 12:47 PM
Tyson's Avatar
this i understand and agree with.
you dont need camber kits. only fools buy them.
Old May 6, 2013 | 09:07 PM
DCRB's Avatar
o/p the control arms will hit the chasis before the ball joints do, about 3 inches back from the ball joint, speaking from experience
88CRXJ
13
Sep 30, 2009 09:35 PM
russianswty
Mar 9, 2007 10:26 PM
turbotime
Apr 14, 2005 09:00 AM
Blaze45
Jul 31, 2003 04:19 PM
93 VTEC
Oct 19, 2002 03:03 PM
