JDM Front - Turn Signal Bulbs
Old May 6, 2013 | 08:44 AM
SpokaneSpeed's Avatar
Default JDM Front - Turn Signal Bulbs
Been searching around for this and haven't found it yet... trying to find replacement turn signal bulbs for the JDM front end headlights...
USDM stock Integra calls for the 1156 bulb, which has the locating tabs at approx 9:00 and 3:00 (if looking at clock). The socket in the JDM front has the locating tabs at approx 9:00 and 2:00...
Did a few searches on here, couple people said to use the 1157 w/ JDM front. Unfortunately the 1157 has the exact same locating tabs - basically same bulb just dual-fil. instead of single. Also saw a thread where someone said just grind off one of the locating tabs on the bulb - tried that with both 1157 and 1156 w/ no luck at all..
Can anyone shed some LIGHT (lol) on this for me?? Thanks
Old May 7, 2013 | 03:20 PM
Default Re: JDM Front - Turn Signal Bulbs
Are you serious... No one?!? Someone HAS to know which bulbs these take...
Old May 7, 2013 | 04:57 PM
B_Swapped93's Avatar
and you haven't thought to take the plug out(you can it's just a clip) and go to autozone or even the dealer
Type Wah
Oct 11, 2007 01:53 AM
tony456
May 12, 2005 02:03 PM
philipwight
12
Aug 27, 2003 04:03 PM
Beave0101
Mar 7, 2003 11:38 AM
DeL SLo
Feb 10, 2003 11:56 PM
