help needed: b series tb on rbc manifold and other rbc tb questions
Old May 5, 2013 | 02:52 PM
xfrankx's Avatar
Default help needed: b series tb on rbc manifold and other rbc tb questions
I purchased skunk2's h2k tb adapter but I was planning on using it on my k24 so I could reuse my new skunk tb that I had. If anyone has done this what did you do about the tps sensor? I due pinned the k series plug but the pins didn't work in the b series plug. They were loose so would I need to get new pins? Also if I cannot make this setup work what adapter plate or spacer plate would I need to run an 04 tsx tb on the RBC? It bolts up but the tb actuator hits the Mani so I know I need an adapter or simply a spacer. I Dont want to run an ep3 or other tb if I don't have to. I'd like to resuse my stock tb with this manifold but I'm confused on what to order to do this. Ideally the b series can be made to work but need a backup plan if it does not.
Old May 21, 2013 | 10:45 AM
kyosoeg6's Avatar
Default Re: help needed: b series tb on rbc manifold and other rbc tb questions
just buy a hybrid racing throttle body and you dont have to run any of that nonsense
but if u insist on running the bseries throttle body , then your gonna have to get the bseries tps plug and pigtail and splice into your k harness. some people like yourself say the pins are not the same so re-pinning it doesnt always work . you could also use the same size pins on your k harness from ur b harness
the tps sensor runs the exact same voltage as a d/b/h/k tps sensor
JDMEMone
Aug 26, 2010 05:30 AM
boosted k20
Jan 10, 2005 01:38 PM
ebp 99 si
Feb 3, 2004 12:47 PM
freezerburnv2
Sep 25, 2003 05:15 PM
zcivicz
Apr 10, 2002 08:58 AM
