CRX Si speedometer hesitation
Old May 4, 2013 | 02:31 PM
jdm_h22's Avatar
Default CRX Si speedometer hesitation
This morning, I disassembled my gauge cluster to grease the speedo cable and to recalibrate the speedometer. With a GPS, I was able to dial in where the needle should be.
Now when I accelerate, I have to achieve a certain speed before the gauge starts reading, usually around 10-15mph. I can tap the top of the cluster as I begin to roll and it usually will actuate the needle.
Did I ruin my speedo?
Is there an adjustment I can make?
Thanks
Old May 4, 2013 | 02:53 PM
v4lu3s's Avatar
RTFM
Default Re: CRX Si speedometer hesitation
why did you take the cluster apart to grease teh cable? usually you can just take the cable off and do it that way...
if the needle is doing that it may be damaged or bent.
rkrone
Mar 9, 2006 03:07 PM
SHJR89CR-X
Feb 23, 2006 06:49 PM
cutt
Nov 12, 2004 06:57 PM
team2n1hatch
Apr 24, 2003 05:07 PM
rasta420
Aug 26, 2002 04:25 PM
