1996 Honda According stalling intermittently
Old May 4, 2013 | 02:27 PM
lmt1979's Avatar
Default 1996 Honda According stalling intermittently
Hi I have a 1996 Honda Accord 4 cylinder that is intermittently shutting off. The vehicle will shut off while driving or while idling and after it does this it is difficult to start back but will start. I have had the vtec solenoid, the valve cover gasket, the spark plugs, wires and distributor rotor/cap replaced as well.
I appreciate any help or advice. THANKS
here are my specs (No check engine light is on)
1996
Honda
Accord
4 cylinder 2.2 liter
175k miles
Old May 6, 2013 | 02:13 PM
Lost Again's Avatar
Default Re: 1996 Honda According stalling intermittently
On a limb...testing needed. A few things to test....main relay, ign switch (elect part), ICM.
Have a volt meter and will to do some tests when the issue happens?
Old May 9, 2013 | 07:53 PM
Gigem891's Avatar
I'll 2nd the Main Relay......was my problem. I bought "better" used junkyard replacement part, melted/resoldered the "large" solder points, let cool, installed, worked fine ever since. Was NOT the ignition key problem, but got new key cut in the process ($10). Good Luck!
ray chong
Sep 30, 2015 05:10 PM
BigBluFan2
Jan 6, 2014 10:29 AM
alwayswynn1010
Oct 7, 2013 06:16 PM
lisam
Apr 9, 2009 02:20 PM
