F/S 95 Integra, JDM front, itr swap
These are pictures of the car last fall before 5 lug and volks I will post pictures in its current when the rain finally stops.
Im selling my 95 Integra that I have put tons of time and money into. This car does not see rain or snow it stays in the garage alot I maybe put 2k miles on it last year total. Its millano red that has been resprayed and looks great and has been taken care of. Last summer I decided the engine bay didn't look good enough for the rest of the car so I pulled the motor and did a mild shave and tuck and had a good buddy respray the bay for me. Turned out great I probably sent around 1500 just in bolts hardware gasket and other little things to clean it up from honda parts unlimited. Then last winter I did the 5lug swap (all parts I put in are listed below) I also put alot of money into the suspension putting all new oem bolts. All though to fit the volks I got a fender roller and decided to try this myself the paint did crack some but nothing serious. Car has been tuned on crome and does have an idle surge when cold till warms up. Front bumper also has a small hole in it under drivers headlight from a hit and run in a parking lot I also have a brand new 00 rear bumper that will go with that is not painted.
Exterior
Full jdm front with black housing and factory HIDs
Oem type r wing
TCSportline carbon fiber hood
aero catch plus hood pins
Spoon rep mirrors color matched
Sideskirts color matched
Interior
Full gsr leather except door panels
Sound deading removed
Nardi 360mm wheel (polished spokes and sliver stitching)
Nrg QR
Nrg thin hub
JDM itr cluster
cruise delete plug
Oem airbag delete
amber clock
itr havc surround carbon
itr carbon ashtray
itr shift boot w/ red stitching
skunk2 shift ****
Oem fog light switch
All bulbs replaced in cluster & havc within last month
Performance
Jdm b18c type r swap
edlebrock intake
Aem fuel rail
walbro 255 fuel pump
rc injectors
Aem intake
lightweight crank pully
mishimoto radiator
blox slim fan
comptech header
full 2.5inch exhaust to magnaflow muffler with turndown
newclutch master cylinder
Goodridge soft clutch line
Hasoprt DS mount
new rear and trans mount oem
ABS delete
AC delete
Cruise delete
Suspension (alot as I just went threw it all this winter and did my 5lug swap so all has maybe 200 miles)
Jdm itr 5 lug swap 36mm
Powerslot front rotors
Centric rear rotors
Hawk hps pads in front
Break best select pads in back
stop tech braided lines on front only
GC coilovers
Tokico whites 5way adjustables
Skunk2 pro series front uppers
hardline racing front lower control arm bushings
hardline racing compliance bushings
New oem tie rod ends
New oem tie rod boots
driveshaft shop 32 spline halfshafts
skunk2 rear upper control arms
emusa lower control arms (polished)
ASR brace w/ASR 24mm swaybar and adjustable links (polished)
Wheels
Volk ce28s 15x7 +35
205/50/15 kumho ecsta xs
I am sure I'm forgetting things but will add if I notice
Feel free to text me 217-619-6748
pm also
Asking 9,500 considering all the nice parts and hard work into it
Exterior
Oem type r wing
Interior
Nrg QR
Nrg thin hub
JDM itr cluster
cruise delete plug
Oem airbag delete
amber clock
itr carbon ashtray
skunk2 shift ****
Performance
edlebrock intake
Aem fuel rail
rc injectors
Aem intake
mishimoto radiator
blox slim fan
comptech header
Hasoprt DS mount
ABS delete
AC delete
Cruise delete
Centric rear rotors
GC coilovers
Wheels
Volk ce28s 15x7 +35
pm also
civicgeek133
Appearance Build Threads
79
Aug 7, 2009 01:37 PM
