California Emissions; '92 Civic LX, 1.6L, 5 speed manual, 240K miles
Old May 4, 2013 | 08:17 AM
Beegee208080's Avatar
Default California Emissions; '92 Civic LX, 1.6L, 5 speed manual, 240K miles
Hello, I am from Ohio and have a '92 Civic LX, 1.6L, 5 speed manual, 240K miles
I moved to CA some months ago; I just took my car for a smog check, and it passed everything except low speed (15mpH) hydrocarbon test.
Here are the relevant fixes I've made to the car recently...
-Spark Plugs (9 months old)
-Fuel Filter (9 months old)
-Oxygen Sensor (2 months old)
-New B-Pipe (1 week old)
Based on this would you guys think that getting a new catalytic converter would do the trick? If not, what can you guys recommend so that I can pass the CA smog test? Are all cat's created equal, or will one brand significantly reduce my emissions score.
Also I notice when looking online for catalytic converters, alot of them say "not for use in CA" etc.... Is there something about my car that makes it not possible to (legally) to put on a new catalytic converter?
Any advice appreciated
Thanks
Old May 5, 2013 | 09:13 AM
Default Re: California Emissions; '92 Civic LX, 1.6L, 5 speed manual, 240K miles
Does anyone know what type of catalytic converter I should attempt to get? What;s the difference between universal and direct fit and which one should I get for my car?
Old May 5, 2013 | 04:39 PM
beecee18's Avatar
1 Retard timing 1-2 degrees from factory spec.
2 Refrain from throwing more money at it (just lookin out)
3 Go pass the inspection
Old May 5, 2013 | 04:43 PM
Former User's Avatar
Nothing at this point indicates the cat is bad. Any CEL codes?
Post the actual emissions sheet. There's information there that may help pinpoint the problem.
How old are the plug wires, distributor cap, and rotor?
Have you checked the ignition timing with a timing gun.
Old May 6, 2013 | 01:57 AM
Thanks for the help; Plugs/wires, cap and rotor all about 8-9 months old.... Heres my results, if there trouble reading it I can get some higher res pictures
Old May 6, 2013 | 06:20 AM
The cat is probably fine as you never failed NOx and everything passes at 25 mph.
Get a free rental of a timing gun at AutoZone and set the ignition timing to spec. You'll find a diagram for the procedure in the FAQs sticky. Follow the instructions to the tee.
Haaarrrrryyy
15
Aug 25, 2016 04:11 PM
creation25
Dec 3, 2012 12:13 PM
spermdoggy
May 25, 2012 06:20 AM
D15B Civic
10
Oct 14, 2010 09:20 AM
NightRiderS2K
Jan 1, 2005 09:20 PM
