CKF Sensor - no signal
Im getting the code P1337: CSF sensor no signal. I have located the sensor and it is indeed unplugged as you can see in the pic. I have a 96 civic with a B16A2 swap. Is it possible the previous owner left out the wires for it? If so what do I do and how important is this sensor?
Do you have the sensor connector coming out of lower timing cover?
If you do and it's two wire:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-depin-2-wire-ckf-3-wire-2876493/
If for some reason you don't (JDM engine for instance):
http://www.ff-squad.com/technet/ckftrick.htm
743power
Audio / Security / Video
Jan 23, 2006 06:11 PM
