Any idea what hp I maybe making?
Old May 4, 2013 | 05:18 AM
tunerboy7065's Avatar
Default Any idea what hp I maybe making?
Hey I have yet to goto a dyno, but I was curious as to what you all thought the whp I'm making. My goal is 200whp. The car is a 97 teg with Jdm front. Only thing different on the car is a 2.5 hi flow cat, 2.5 vibrant muffler, and a street tune.
Engine:
JDM b16 head
Port and Polished
Buddy Club cam gears
ITR Cams + internals
Hytech Replica Header + Test Pipe
T1R full exhaust 2.5 in
Ebay intake + k&N air filter
Skunk2 Pro S intake Manfiold
Hondata Intake Manifold Gasket
AEM fuel rail + AEM FPR
Fuel Pressure Gauge
NEW NGK blue Wires
NGK spark plugs
Skunk2 short shifter
Walboro 255 Fuel Pump
GSR Tranny
Brand New OEM pilot + Throwout bearing
Both Tranny Seals
Exedy Clutch
Fidanza flywheel
GM Syncromesh filled 11/11/09
Block:
GSR 81mm Bore
New JE 12:1 Pistons
Eagle H beam rods +ARP rod bolts
ARP headstuds
Crank Polished with .10 oversided rod bearings
New ACL Race rod/main/Thrust
OEM Headgasket
New ITR oil pump
All new OEM bottom end gasket set
Old May 4, 2013 | 05:45 AM
nealnanoHX's Avatar
Default Re: Any idea what hp I maybe making?
My guess 185-190whp. But you need to get on a dyno and get it tuned.
Old May 4, 2013 | 06:11 AM
98vtec's Avatar
moderator emeritus
1000whp. Put it on the dyno and find out.
D-Rob
607
Nov 14, 2015 10:32 PM
fastlittlecivic69
Sep 5, 2010 04:24 PM
Echo7847
15
Apr 23, 2007 08:22 AM
bambam
Apr 1, 2006 11:45 AM
DC2tuner
Aug 4, 2005 04:15 PM
