88 ef need help asap
Old May 3, 2013 | 04:20 PM
Kyle88ef's Avatar
Default 88 ef need help asap
Ok Guys I can't figure this out. I have a 88 ef hatch 1.5 all stock but exhaust and intake and its a 5 speed ok my prob is it dies when I try to drive it down the road. My fuel pup went out 3 days ago so I replaced it along with the fuel filter. The car will start great and idel but if you easily press the gas it dies or Boggs down but if u press it wide open it will rev up but is rough. And sometimes when it idles it will idel up and down up and down so today I I backed it out and tryed to drive it but as soon as I left off the clutch it starts to jerk and bogg out and won't rev up and go. I have done a compression test and it was 150 all the way across. I have checked to see if it gettin gas and there's plenty of fuel pressure I have tried the tps and map sensor. It's gettin spark but the plugs are fooled. There black dry crap on em. I cleaned em up and put em back it but after I cranked the car and let it run trying to figure this crap out the we're black again today. So I pulled off the cat but it not clogged. I can't figure it out any help will be great thanks
Old May 3, 2013 | 04:53 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 88 ef need help asap
Is the black stuff like soot?
What pump did you put in and how much fuel do you have in the tank?
Common problem is use of a Walbro pump and using the wrong sock for it. Anything under 1/4 tank creates problems.
Old May 3, 2013 | 05:10 PM
Kyle88ef's Avatar
Yea it's soot and the brand was oreilys I guess its called besttest.
Old May 3, 2013 | 05:11 PM
Kyle88ef's Avatar
I used the old sock tht in there
Old May 3, 2013 | 05:20 PM
Kyle88ef's Avatar
**** I just looked up what the strainer was it wasn't what I was thinking. No I didn't even use a strainer on it but my old fuel pump didn't have one when I pulled it out
88rhdEf
Mar 29, 2015 02:38 AM
nycpatron
Nov 22, 2012 06:52 AM
Seventy_k
Mar 9, 2010 04:58 PM
legendboy
Nov 3, 2004 10:57 AM
