EG Hatch ; none of the rear lights work
Old May 3, 2013 | 02:32 PM
EG92DX's Avatar
Default EG Hatch ; none of the rear lights work
I'm having an odd problem with my rear lights. They don't work , none of them. Brake, Daytime/Runner , and reverse. Odd thing is that my headlights/corner lights work , low and high beam and dash dimmer lighting even works. What can be the problem? I checked fuse 19 thoroughly, only thing I'm guessing it can be is wiring, what wires under the dash have to associate with rear/tail lights. Brake switch may be bad but it can't stop the daytime lights from coming on correct? Any help appreciated, thanks.
Old May 4, 2013 | 11:13 PM
EG92DX's Avatar
Default Re: EG Hatch ; none of the rear lights work
bump; Dash Light and Head lights work , tail lights don't! What's wrong?
Old May 4, 2013 | 11:20 PM
SLURS's Avatar
Check the break peadal switch under the dash it might not be engaging out just bad
Old May 5, 2013 | 12:51 AM
EG92DX's Avatar
Is the brake pedal supposed to press on the black button on the switch when depressed?
95GSRtegTN
Nov 15, 2018 10:19 PM
Johnoolo
Jan 17, 2014 08:13 AM
mel
12
Nov 9, 2006 09:04 AM
citrus3000psi
Oct 13, 2005 12:27 PM
