car wont start
ok first off let me tell you about the car its a 95 ex coupe with a jdm 98 spec itr obd2 motor and ecu using a jumper harness to car been running fine up untill three days ago car started sputtering bogging down and stalling thought i got bad gas so put on new fuel filter and drained tank car started ran good made it 10 miles and cut off would just turn over and over will no starting so i replaced the fuel pump thinking it was the problem still no start i know im getting fuel cuz it flooded my old plugs put in new plugs still nothing so replaced igniton coil sense that tested at 1 ohm and spec is 0.6-0.8 ohms car started but if i gave gas it would bogg down and just about stall out while running it threw a code 23 for knock sensor so bought new sensor still wont start will just crank and crank
while trying to start this morning i noticed the cel came on so i pulled the codes and got a no 9 for cyl postion sensor and a code 20 for Electric load detector basically im at a loss and need some help
when in the hell did i say that code 20 will prevent the car from starting? the bad eld will just interfere load and no load voltages, which to me is more dangerous then the car not starting. specially if you like 15 volts running thru your entire system. that would be MY first priority, find out why its throwing an eld code, my homie has a 92 civic hatch kept throwing a eld code and car was running like crap, and it would stall if you revved it and let go of the gas. once we found the bad ground. eld code never came back up. car ran smooth. never stalled again ty. THIS IS FROM EXPERIENCE. you can go ahead and believe anyone. im not telling you to believe me. just saying what i went thru. and this took 2 days of diagnosing EVERYTHING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Open test:
Plug the distributor connector back in. Unplug the ECU connector that has the 2 Cylinder Position Sensor wires. Measure resistance across those two pins of the ECU connector. Do you still measure 360 Ohms?
dlove024
Mar 4, 2009 04:09 AM
yusoslo
Sep 28, 2003 12:29 PM
