Firing Order for 92 Accord
Old May 3, 2013 | 07:56 AM
hometheaterman's Avatar
Default Firing Order for 92 Accord
My friend has a 92 Accord DX that they are doing a tune up on. I got called over to help only for them to have no idea where the plug wires they took off go. If I'm understanding correctly 1342 should be the correct firing order and the plug the furthest from the distributor to the closest are plugs 4,3,2,1? Does anyone have a picture of which wire goes where? Each picture I'm finding online shows the 1 wire in a different spot, so I have no idea where to start it. The pictures also don't have the setup with the coil wire in the middle. Does that change anything? Thanks.
Old May 3, 2013 | 09:50 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Firing Order for 92 Accord
There should be some marker near the #1 tower for identification. Firing order is 1-3-4-2, rotation is clockwise.
Cylinder numbering is [Dist]-4-3-2-1.
sgull
Feb 19, 2013 07:44 AM
cwo715
Aug 6, 2008 05:05 PM
gvox
Jul 13, 2006 12:12 PM
milleniumabyss
Jun 9, 2006 05:38 AM
