CRX stalls when I coast
Old May 2, 2013 | 09:04 PM
cmkwood's Avatar
Default CRX stalls when I coast
My 91 CRX HF stalls when im driving over 10mph and throw it in neutral to coast to a light. when im under ten the RPMs don't drop under 750 so its good but over that the RPMs just keep dropping till it stalls. When this happens the battery light comes on right before the stall. When I got the car it did it and was throwing a code for ELD so I changed the under hood fuse box and it stopped. Then one day my battery got loose and I tightened it up and this started back. Some one told me maybe grounds but they seem decent or at least the two I could find did.
Old May 4, 2013 | 12:47 PM
go-part's Avatar
Default Re: CRX stalls when I coast
Have you checked your TPS?
Start there and try to rule that out as your problem.
Old May 5, 2013 | 09:12 PM
cmkwood's Avatar
Well turns out that all my ground on the granny lead to the negative post on the battery. So I grounded it and the problem stopped. Wish I had done the swap myself.
Old May 5, 2013 | 09:15 PM
cmkwood's Avatar
Turns out all the grounds on my transmission were connected to the negative post on the battery and not grounded. So I grounded them and it fixed. Wish I had done the swap myself.
stoney13142000
Dec 9, 2011 12:05 PM
c1turbo
Oct 8, 2008 10:53 AM
CoolRedXylophone
Jun 9, 2008 01:41 PM
EFMAN
Aug 31, 2005 08:56 AM
$criptah
11
Nov 26, 2001 08:19 PM
