Honda CR-V & Element 2WD & 4WD Element & CR-V
Cooler tranny fluid help
Old May 2, 2013 | 06:35 PM
Deviant117's Avatar
Default Cooler tranny fluid help
I have a 2000 crv with 197k miles. Motor is stock, tans is auto. Transmission shifts fine until it reaches normal operating temperatures. Then first gear (and first gear only) slips until just under 2k rpm, then it launches. If I idle and the temps come back down, the trans shifts fine again... Any recommended tranny fluid that runs cooler or radiator fluid that runs cold? Trying to get a little extra life out of this tranny. Thanks!
Old May 8, 2013 | 05:16 PM
trucku's Avatar
Default Re: Cooler tranny fluid help
You can try Lucas transmission fix. It is very viscous. I would try that if you don't feel like the need for changing the fluid.
My trans was shifting inconsistently. I used half a bottle 1/2 bottle of Lucas transmission fix, and it helped after a few drives.
http://www.lucasoil.com/products/dis...iid=29&catid=2
cabron
Honda Civic (2001 - 2005)
10
Feb 6, 2011 09:36 AM
Rikaro
10
Jun 6, 2007 04:38 PM
FLCivic
10
Apr 14, 2004 07:19 PM
LOwrestling2001
Apr 28, 2002 12:55 PM
