Will ej struts work on my ef?
So I heard I can use ej struts on my 91 ef9. But what do I have to do to make them fit. I'm trying to get these blox ( http://www.jhpusa.com/store/pc/viewP...idproduct=8810 ) struts. But they don't make them for ef. Do they fit perfectly or what do I have to do to make them fit perfectly. Any help would be appreciated. Thanks in advance!
If you used EF fork then you would have to modify them.
They forks are the same height as the EF, but the inner diameter is larger on the EJ as the shock is fatter.
The shocks will fit forks from
94-01 integra
92-00 civics - except 99-00si
The 99~00si fork is wider at the bottom where it bolts to the LCA
The rear EF and EG shocks are the same. So take a look at the bushing modification that is required to mount the EJ shock into an EG (not much to be found for mounting EJ to EF)
94-01 integra
TURBO B
Aug 14, 2003 10:51 PM
