Help! 1994 accord
Hi. My 94 accord ex is missing so bad it barely runs. When you get it to 2000rpms, it drives a little better. I jumped the diagnostic plug and it gave me a throttle body code. Put 2 throttle bodies on there and it still is having the problem.. If this sounds familiar, please help me. After i reset it, it would run fine again. Now when I reset it, it doesn't. Weird car. Also it is having flaring from third to fourth gears (auto trans.). The abs light is also on. It is so discouraging being a female and not knowing how to fix this crazy car.
if it's having trouble deciding between Overdrive and third it definitely sounds like a Throttle body position sensor. It is the electrical unit on the back of the throttle body, unplug the connecter and check for any corrossion/dirt/debris. If you can, post the exact code the MIL is throwing.
It sounds like it is in the wiring instead of the sensor itself considering it has happened with 2/3? different units.
hon2984
Jan 17, 2008 08:57 PM
SkyliteCustomz
Honda Civic (2001 - 2005)
Nov 12, 2007 01:59 PM
