SH Transmission on 4th gen?
So I've been trying to do some research, but all I can find is compatible engine swaps. My third gear is out so I have a 4 speed prelude >.< all I wanna know is if an SH tranny, would it fit properly on my 4th gen?
If you have any links feel free to post them!
Thanks H-T!!
Thanks H-T!!
Anything is possible... however, the time required and the cost to modify your car to utilize the "SH" transmission would be very high:
Here are a few highlights...
You must use the ATTS unit, which will NOT bolt to the back of your block. Extensive welding would be required OR a "SH" engine in place or your current one.
There are 11 sensor/solenoid plugs located on the ATTS unit... all of this would have to be wired.
An "SH" computer and ATTS control would have to be utilized... they are OBD-II components and would require a different fuel tank, evap upgrades and a second O2 sensor post-cat to be eliminate all CEL's.
I suggest you repair your current 3rd gear.
