88 civic dies when givin gas
Old May 1, 2013 | 05:45 PM
Kyle88ef's Avatar
Default 88 civic dies when givin gas
I have a 88 ef hatch d15. All stock but intake. 5speed. My car will bogg out if I put it in gear and try to drive it , it will idel fine it wil almost die when I give it gas but when I let off the gas and push in clutch it's fine. I have put a new fuel pump and filter and its getting good gas. Can't figure it out
Old May 1, 2013 | 08:05 PM
MONSTERZC's Avatar
Default Re: 88 civic dies when givin gas
unbolt the cataylic converter. to see if it will runs better. if it does you have a stoped up converter.
Old May 2, 2013 | 05:40 AM
Kyle88ef's Avatar
i will today. Even if i press the gas a little it will almost die.
Old May 2, 2013 | 05:20 PM
MONSTERZC's Avatar
If the converter checks out ok. Check for vacuum leaks. Then check timing to make sure the belt didnt jump time.
Old May 3, 2013 | 04:26 PM
Kyle88ef's Avatar
I have checked all the lines and the cat was ok. I don't have a timing gun to check the timing. When I try to drive it it jerks and bogs down about to die till I press the clutch in and then it idles fine
Old May 4, 2013 | 05:03 PM
MONSTERZC's Avatar
you dont need a timing light you line up the mark on the timing cover to crank pulley . And pull the vavle cover and the upper cover to make sure all the mark are alinged up properly
Srt.ej1
Oct 22, 2015 10:23 PM
BLU CIVIC
Sep 17, 2007 08:13 PM
newbster
Oct 13, 2006 09:43 PM
mickiemagik
12
Jul 6, 2006 07:48 AM
Tr0LL
Jun 11, 2003 01:17 PM
