Aem 5bar map sensor question.... HELP
Old May 1, 2013 | 12:29 AM
Almtrhb's Avatar
Default Aem 5bar map sensor question.... HELP
Aight i installed a 5 bar from a SF 4 bar. The car worked fine before doing this and now at 8800rpm the car hits a rev limiter. On the log the rev limiter tab gets enabled but The rev limiter on the ecu is 10,500... Every pass on the dyno it does it. Has any1 had a issue like this? could it be a bad sensor, also seems like we keep adding fuel but it doesnt help. Even tried erasing the ecu and reloading the map.
Thinking changing dizzy!!!
Changing the ecu!!!
or wire the 4 bar again to see if that works.
Need to make it to vegas this wkend And YES ive been reaserching for the last fuccin 5 hrs on this ****. Goin on the dyno again tomorrow Plz your input would HELP...
Txt me your answers that would be faster than me loggin on here since ill be busy at the shop Thanks
714-388-7303
Old May 1, 2013 | 03:03 AM
DraginX's Avatar
Default Re: Aem 5bar map sensor question.... HELP
I would ad the pigtail for the sf 4 bar and try it just to eliminate the possibilities of it being that.
Was anything else changed when the maps were swapped out?
Old May 1, 2013 | 06:24 AM
Mo_Spec's Avatar
email me a log and the tune, i'll look through it and see whats up.
Bluek24@gmail.com
Old May 1, 2013 | 03:18 PM
Almtrhb's Avatar
Aight problem fixed... It was the 5 bar map sensor that was brand new out the box... Repinned the wiring back to normal and it worked fine....
Thanks for the help
Kid-jdm-teggy
Feb 19, 2015 03:35 PM
justnprsh07
Mar 11, 2011 02:10 PM
Hybrid_EF
Mar 18, 2010 08:52 AM
slowteg550
Jun 18, 2006 09:25 PM
89civic1.8T
Jul 12, 2002 11:22 AM
