Camshafts(S2T2) installation question.
So i'm ready to install my tuner 2 camshafts and go get my set up tuned BUT I need to get to my tuners first(2 hour drive). So my question is can I install them and just disconnect the vtec solinoid plugs(thus no vtec) and drive down i have the springs and retainers installed all ready and will set ignition timing along with mechanical before I go. I live in the middle of no where so this 2 hour drive really is a must.
but CAN I do it if needed it's mostly highway cruzing at 4K rpms in 5th.
bump sorry I just have to call and get an appointment soon so im needing to know CAN if just disable vtec for the ride down im not a fast driver so the car gets gently driven 90% of the time.
You should fine as long as you keep it below 20% throttle (very light load)cruising only, no full throttle runs.
Ok dumb question but can you drop these cams in and just run around with them I keep seeing(ppl in the civic section) just installing them and driving around till "I get a tune" . just want to know can you do this not tracking or anything like that just my DD
have Springs+ retainers already in.
Tune never happened (clutch+flywheel went along with breaks and needed to pay for school)
Get a tune if you install the cams.
Simple answer.
Can you drive around with the new cams untuned?
Yes.
Should you?
I wouldn't.
I don't understand why so many people overlook tuning.
Would it be the same deal with a "base mapped" ECU ? I know it's not good just need to get down to said tuner's shop when I get the $. What does it do damage wise make it run rich/lean ???
Now, take it easy, drive slow, and go get tuned.. or tow it..
If you don't have the skill to program an ECU, you'll likely have problems even if the baseman is good. There are many things that could be off and you'll have no idea what is the cause. I know this from experience working you peeps.
With ITR cams you might have a chance. Many, many tuners can't hang with cams requiring big deviations from stock cam pattern. Seen it over and over.
derekhh
Mar 1, 2006 09:42 AM
